ok, so... if you've looked in my profile it is obvious the system i'm running should be pretty much up-to-date, well.. good enough to burn some simple dvds. i download tv-shows from another country and the quality of them are average, they take less than 30min to download at 300KBs and each run about 35-40 minutes long. that should give you a clue on wht kind of quality the video clips are. i try to make a compilation of them on a dvd to send to my parents (all together each dvd should be from 2-3 hours in length) since they miss the old soap-opra'z from our home country, but using the latest verson of nero, it takes me 12 to up to 18 hours to transcode wmv to dvd mpeg!
i figured it waz becauze i waz transcoding wmv files, so then i started to download random things and started transcoding avi, divx, xvid, mpeg, and mpg, but it still takes about half a day to transcode. finally one day i try to burn the same files (WMV) on my tower uzing arcsoft showbiz, and transcoding the same files takes only an hour to an hour and a half at most. my tower is not even half the speed of my labtop, and has half the ram. the only problem i have iz that the damn tower's burner is super picky about the media that it burns on, so after transcoding i have to move all the VOB files to the laptop and burn it there.
can anyone tell why transcoding on my laptop takes a million years to transcode? and wht can i do about it?
Results 1 to 9 of 9
~Nguyen
don't use nero to do it. convert you wmv files to mpg files using somethign like tmpgenc plus. then import the mpegs into nero.
i recently did a a convert of a wmv file that was fairly lowish quality, 46 minutes in length, took just over 20 minutes to make to a 352 x 288 mpeg2 file with audio.Some people are only alive because it may be illegal to kill them -
If they're not great quality to begin with, just use CQ-VBR at about Q70.
Set Motion search precision at Motion Search Estimate (fast).
Set Max and average bitrate less than 4000, or even 2500 (SVCD quality).
Set to 352x240/288 aspect, or Half D1 anyhow.
Single pass will be twice as fast as 2 pass, and MSE fast will be even quicker..Cheers, Jim
My DVDLab Guides -
Originally Posted by yersweetazn
ok, so i've been uzing tmpgenc plus, transcoding or converting a 20min video takes about 25 min in a low resolution video with cbr mpeg-1 layer II Audio. so it is still taking longer or at least as long as watching the entire video clip. i do have the priority set to high for both options. is there no way i can transcode in at least half the time it takes to watch the whole video?
~Nguyen -
There faster mpeg encoders than TMPEG. CCE or Main Concept,but they require muxing the file.
No.
It takes a thief
By zoobie in forum Off topicReplies: 5Last Post: 16th Mar 2009, 12:59 -
Hours of Music without Hours of Video Data in DVD Architect
By Guff22 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2008, 21:23 -
Backing up HD takes too long?
By videobread in forum ComputerReplies: 4Last Post: 26th Jul 2008, 13:17 -
Tyra takes her pants off on tv...
By Cirone in forum Off topicReplies: 6Last Post: 15th Feb 2008, 14:43 -
PAL To NTSC DVD conversion takes 6+ hours???
By lnong in forum DVD RippingReplies: 4Last Post: 12th Jul 2007, 01:56
