Can anyone recommend a program that will allow me to add a fade from black and a fade to black to a video file without losing the audio? My Nero will do it, but it changes the audio from 5.1 to 2.0 and the audio doesn’t fade with the video.
I want to take a clip from a film and I want the audio and video to fade up and fade out. I'd then like to dump the video and audio into DVDLAB and master it for DVD.
-BSR
"The secret to creativity is knowing how to hide your sources."
--Albert Einstein -
Dont know if it would be of any use to you but I have Ulead Videostudio 7 which, although it is very basic, will do the kind of fading that you require.
I thought that this would have been a standard feature on most video authoring tools ??"The most overlooked advantage of owning a computer is that if they foul up there's no law against whacking them around a bit." -
You can try Womble MPEG VIDEO WIZARD. Important Note: the output will be an MPEG file. MVW is a bit expensive, but it is one of the few programs that works well with MPEG files. Womble offers a 30 free trial period. (not sure about the audio.)
avisynth - how to fade in (but audio has to fade in faster)
By adom in forum EditingReplies: 13Last Post: 31st Jan 2011, 12:45 -
Fade in Fade Out CD Music Software
By mn072065 in forum ComputerReplies: 0Last Post: 6th May 2008, 08:23 -
Fade in Transition Fade out scenes
By ancient in forum Authoring (DVD)Replies: 4Last Post: 30th Nov 2007, 05:04 -
how can I add "Fade in / Fade out" effect in my video clips
By mb508 in forum EditingReplies: 5Last Post: 9th Jul 2007, 16:02 -
Fade-in\Fade-out filter, VirtualDub MOD
By GangstaRap in forum Video ConversionReplies: 3Last Post: 21st May 2007, 20:58
