I know this has been beaten to death. But I am still unclear on a couple of things. Project wizard in TMPEnc determines the field order of the avis that I have capture with Picvideo and a Leadtek 2000XP to be "top field first (field A)". My encodes to mpeg with TMPEnc then work fine when I view them on TV. The default setting in CCE is "upper field first". Is this the same as "top field first" in TMPEnc?
In Ulead, the default is "frame-based", but to get the correct output I have to select "field order B". So is there any way to tell what I should select before I start to encode? I tried g-spot with an avi, but I did not see any palce where field order was indicated. Besides this doesn't necessarily determine what settings to use for different programs since they appear to use different terminology.
Finally, what determines the field order in a capture, the card, the codec or the program?
"The default setting in CCE is "upper field first". Is this the same as "top field first" in TMPEnc? "
no - cce is always TFF for the output , you just select what your source is ..
"what determines the field order in a capture, the card, the codec or the program"
if it is hardware capture - the card , unless you change it (not always even possable)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
BJ_M, Thanks, but I am not quite sure if you mean I should deselect "upper field first" in cce?
depends what version you are using , there is no such setting like that in the current version of sp and im not sure how express is set up ..
When I unchecked the "upper field first", the video looked fine on the TV. Just wish I could figure out a way to determine what to do without wasting a disk. I don't have any decent RWs.
AVI Field Order
By Ash McKenzie in forum Newbie / General discussionsReplies: 1Last Post: 1st May 2012, 01:52 -
do I have a field order problem ?
By davexnet in forum Video ConversionReplies: 9Last Post: 13th Dec 2010, 14:41 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 01:38 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 17:14 -
Need to change field order
By Loko in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2007, 21:32
