My liteon 5001 has come to this point where I can only use dvd+rw to record as dvd+r usually fails to be finalized whereas dvd+rw works without finalizing. The problem I am having is that dvd+rw is able to be recorded like 2-3 times before becoming defective, i.e. the resulting disc has read errors when ripping on pc dvd-rom. Is there any way to solve this issue? Perhaps someone had the same problem? I am particularly interested to know if I can solve the dvd+r issue.
I have a LiteOn 5001 based player and I'm able to reuse my +RWs quite a lot. I buy Memorex in Canada which are Ricoh/Ritek made. I believe they are the same as the Maxell +RWs. I generally can reuse them around six times (rough estimate since I don't keep track), afterwhich, I need to do a full format on a computer and then they'll be good for another six or so times.
If you're having problems with both R/RW, perhaps your laser is dying. Luckily, the LiteOns use regular IDE LiteOn DVD writers.
Merge two defective DVD's into a working one
By ET3D in forum EditingReplies: 3Last Post: 3rd Oct 2010, 00:14 -
Software for recovering a defective DVD
By base689 in forum MediaReplies: 5Last Post: 26th Sep 2007, 02:07 -
Extracting MPEGs from defective DVD's
By TPFKAS in forum Video ConversionReplies: 3Last Post: 26th Sep 2007, 02:01 -
Possible to rip a defective DVD?
By gail22 in forum Newbie / General discussionsReplies: 37Last Post: 22nd Sep 2007, 14:02 -
DVD Recorders that records to + media?
By SteveMKIIDub in forum DVD & Blu-ray RecordersReplies: 5Last Post: 21st May 2007, 11:54
