Hi im hopeing someone can help me i have videos in .avi format with vbr audio and i want to encode them to mpeg. recently I had a small peice of software that coverted the audio from vbr to cbr without having to seperate the audio from the video I lost it when i recently reformated my hardrive but i can't remember where i got it from or what it was called. If any body knows what the software is please let me no what it is and where i can get it from. due to me losing this I have tried using virtual dub to change the audio to .wav but when i try to save the audio back with the video as .wav it saves the video back as an .avi file at something stupid like 78gb am i making a stupid mistake or shouldn't it be doing that.
Some one please help me
Be sure to set Video->Direct stream copy in virtualdub or the avi video will be converted to uncompressed = several gig.
cheers that has worked
if anybody knows about that software please let me no what it is. -
one more problem the audio is now out of sync with the video and when i try to encode the video using tmpeg encoder it says there is no audio just the video?
Load AVI in Goldwave, save wav.
Load AVI in VirtualDub, select WAV audio, select your wav.
Set Video, direct stream.
Set audio, full processing, select VBR MP3 @desired bitrate under Compression.
Save AVI.
Done.
/Mats
Joining abr vbr cbr audio videos (maybe cut/paste too)
By ZZen in forum EditingReplies: 2Last Post: 29th Jun 2009, 09:26 -
cbr to vbr
By dynamix1 in forum AudioReplies: 1Last Post: 17th Mar 2009, 15:12 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 04:55 -
Convert divx vbr to cbr audio - video freezes (possible reason & soluti
By lingyi in forum AudioReplies: 0Last Post: 4th Oct 2007, 16:51 -
VBR or CBR?
By dizzie in forum ffmpegX general discussionReplies: 1Last Post: 29th Jun 2007, 15:28
