I've built a new PC, the priority being to protect myself from past attacks and HD failures. I think this should do it:
First I no longer use IE other than when necessary. FireFox is my number one browser.
Secondly I'm using a Linksys router, Norton real-time AV protection along with SpyBot S&D as a first line of defense.
Thirdly I've backed up my OS using Ghost to a separate HD but on the same computer. All data files are backed up to a separate PC on the same home network.
Rather than do incremental Backups of my OS I plan on doing full OS backups. I'll keep at least one on HD as I roll off older versions to DVD.
BTW about three weeks ago My Pc was first attacked by a IE hijacker. I had no more than remove it than a I had a HD failure in my raid array.
Results 1 to 30 of 37
Big Government is Big Business.. just without a product and at twice the price... after all if the opposite of pro is con then wouldn’t the opposite of progress be congress?
What sort of firewalls do you use?
If you don't have the firewall turned ON in Linksys controls, you may as well leave the door open.
Add to that, something like Sygate, that detects outgoing as well as incoming, and you MIGHT be a bit better protected.
If your backups are stored on the array, they're no better than your working drive, depending on which type of RAID you're using (striped?).
Norton AV is as good as any I suppose, although it's huge bloatware IMHO.
Spybot is only good to remove problems, other than Activex controls. Try SpywareBlaster as the first line of defence for your browser.
On the linksys...are you using NAT, and forwarding ports, or just defaults, routing port 80 to port 80 etc.?Cheers, Jim
My DVDLab Guides -
My linksys has not been configured out of my ignorance I supose. Can you sugest a site to help me with this?
I no longer use RAID an I back up my os to a diferent drive. .. and I'l checkout spyblaster
thanksBig Government is Big Business.. just without a product and at twice the price... after all if the opposite of pro is con then wouldn’t the opposite of progress be congress? -
Most of the routers use a web based interface.
You usually get into it by using the programmed ip address.
It may be 192.168.1.1 or something.
The rest is straight forward.
The only time you would use a demilitarized zone is if a program will not function properly behind the NAT firewall. -
Originally Posted by reboot
Good to know gummy
I'm not familiar with Linksys, as they're almost double the money of other good routers here.
SMC Barricade (and others) are more prevalent.
Try this: http://www.linksys.com/tech_helper/config.htmlCheers, Jim
My DVDLab Guides -
whats a good firewall on a non XP system? Currently i use Zonealarm but after looking in the latest edition PC Mag, it shows ZOnealarm isnt that good in protecting.
Also do a search on FIrefox, there are some good speedy tweaks out there. I started using it this past week. -
Sygate personal is free. Definitely the best alternative to ZA free, which is now crippled.
Cheers, Jim
My DVDLab Guides -
All that will help, but you still need protection from installing an app that has spyware in it. My buddy installed KazaaSpeedup.exe and he got infected badly.
Check out Webroot SpySweeper, which stays resident and constantly alerts you to registry modifications and ActiveX controls being installed. -
this day and age its getting pretty obvious what apps. probably have adware/spyware.
all of them
Yer beggin' for problemz..... Do you really want to issue a challenge?!
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
I would consider trying this: Microsoft® Windows AntiSpyware (Beta) It works great! The best one I've found so far. But I would still use it in conjunction with the others
no matter what u do your computer is gonna get jacked sometime. all u can do is try to prevent it. #1 if files are all that important and personal dont hook the computer up to the internet or at least encrypt them. #2 if anything is all that important to u, back it up...nothings a sure bet even with all the protection in the world. just my 2 cents
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
Originally Posted by Shocker Milwaukee
Some tips for your router. You may want to disable remote administration if you haven't already, as well as changing the password to something other than 'admin'.
Nothing can stop me now, 'cause I don't care anymore. -
Good suggestions all but I'd suggest taking some more steps. I use zone alarm pro(a cracked version) and love it but I use an older version (4.5) because I've heard with the newer has conflicts with bittorrent. I like it because I know exactly what's going in and out of my computer although my router firewall blocks 90% of incoming attacks. Also i'm used to it . Always set your router firewall on and change your password. I use AVG virus protection, it works fine, and it's free.
Set up your antivirus so it scans any downloads automaticly.
Always scan your downloads, if you're expecting a zip or rar file and it ends in .exe it's probable a virus.
Go to http://www.blackviper.com and find out what all those processes that run on your computer are and if you can turn them off. This will also help you recognize any unkown programs that are running on your computer.
If you want to speed up and optimize firefox go to: http://forums.mozillazine.org/viewtopic.php?t=53650 this is where all those tuning tips orginally came from.
I've never had my computer hijacked or had any major virus.
On the other hand I've never used internet explorer either.
That might be why.
You are in breach of the forum rules and are being issued with a formal warning. No warez!
/ Moderator Cobra
***Warning expired*** -
Personally I Like the firewall functions in Dlink routers better then linksys. but anything is better then none.
in my opinion, i dont think one can completely protect themselves from hackers or hijackers. using all the software such as firewall, anti-virus, spysweeper etc etc.. is good but will only minimises the chances of someone doing so.
Originally Posted by waheed
All you can do is reduce your chances. On a computer, you are never completely safe. -
Also the more expensive but shortcut method would be to go buy a mac.
Originally Posted by Flaystus
Keep the PC and run Linux -
Thanks for the advice Aerodige and I do go to black viper every so often to eliminate unneeded services.
Do you guys really think my heading "try and touch this hijackers" is an invite?
However I do expect at some point to get hijacked/infected again. Thats the reason for Norton Ghost backups of my OS. I like to refresh my OS once a year regardless. No I can do it much faster and safely.Big Government is Big Business.. just without a product and at twice the price... after all if the opposite of pro is con then wouldn’t the opposite of progress be congress? -
Best way to protect yourself - Remove the modem cable
Originally Posted by glockjsI forgot I read that by the time I posted mine. Not trying to steal your thunder or anything :P
Originally Posted by bazookaPhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
Touch screen monitors or all in one touch screen pc?
By Rudyard in forum ComputerReplies: 4Last Post: 1st Dec 2010, 09:02 -
ipod touch/iphone
By Kurgan71 in forum Video ConversionReplies: 0Last Post: 27th Aug 2008, 09:50 -
ipod touch
By warwickk in forum Newbie / General discussionsReplies: 1Last Post: 31st Dec 2007, 12:13 -
iPod Touch Settings?
By threestain in forum ffmpegX general discussionReplies: 3Last Post: 9th Oct 2007, 01:45 -
pc reboots if i touch the case
By bigmicka in forum ComputerReplies: 10Last Post: 1st Jul 2007, 05:12
