Hi ,
Iam having a real strange problem latly . When burning a dvdr iam getting verify errors around 65% till the end . It happens to almost all dvd's i burn. DVD Decryptor mostly stops with an I/O Error around 71% ( while verifying ). There are no problems burning the dvd itself - just in the verify . When i compare the dvd with DVDInfopro then the reading will slow down so much that i have to stop it .
When playing the dvdr's in a standalone it will stop to the end of the movie and then after 1 or 2 seconds continue playing at the same spot .
I use a NEC1100A dvdwriter ( flashed to a nec1300 ) which has never been a problem before - just as the bulkpaq media iam using . The write Speed is 2.4x ( DVD+R).
The only thing i can come up with is that the writer is somehow fuxored that it doesnt cleanly write towards the end of a dvdr .. can that be ?
Well thanx already in advance ,
Hi ,
thanx for the quick reply - iam using bulkpaq media - which has worked fine before for all kinds of purposes . Well maybe this spindel is bad - coz i already had like 5 bad ones ? -
Sure sounds like media. A common complaint here.
The cheap media often has issues writing a full disc. Anything over 4GB with the cheapo stuff is iffy at best. It's also one of the reasons why many standalone recorders limit it to 4GB max on a disc ....for compatibility with the cheap stuff.
Get some good media like TDK or Taiyo Yuden. It's not much more expensive when you figure you can use damn near every one without coasters
So it is not very likly to be the writer ? I thought maybe i have to get one of those cleaning disk's ?!
Iam just asking because the spindel i had before worked just fine . -
Maybe try getting a few (maybe 5?) good brand disks like verbatim and burning - see if you get any bad ones.
How to verify mp4 stream compatibility with iPad
By Gargalash in forum MacReplies: 10Last Post: 25th Apr 2011, 09:46 -
How to verify burned Music CD is compliance to all CD players ?
By SingSing in forum AudioReplies: 9Last Post: 26th Sep 2010, 20:28 -
How to verify a successful encode
By maxxed in forum Newbie / General discussionsReplies: 6Last Post: 8th Feb 2008, 21:31 -
ImgBurn2 Verify Failure: Curious as to Why ?
By Seeker47 in forum Newbie / General discussionsReplies: 12Last Post: 27th Jan 2008, 14:28 -
Is it really possible to verify a DVD burn?
By TheFamilyMan in forum MediaReplies: 5Last Post: 19th Oct 2007, 19:22
