good Morning,
after reading for the last few dayshere i got a lot of information
thanks for that first.
I would like to know if someone knows a fast software for producing vob files i have a two hour movie edited with pinnacle studio 9 and with P9 it takes forever to get the vob file i do ...create disc but not burn...,so my idea finalize the film save it and then open it with this "?magic fast Software" someone any idea?
thx for help
oh and maybe an easier way to get vob files back to mpg files than decrypter.
the_Rippel
If you are working with dvd-compliant files it shouldn't take very long to author, especially with your PC. I suspect you're working with non-compliant files and your authoring app is transcoding to DVD-compliance. If this is the case you can't get around the time unless you start with compliant video files.
Read more about DVD-compliant files here:
I am pretty sure that Pinnacle Studio 9 re-encodes everything, compliant mpegs and all.
For authoring, which is the creation of vobs in a structure that DVD players understand, I use TMPGenc DVD Author. Two hours of mpeg compliant video will take 15-22minutes. TDA is an authoring app and is not intended for video editing. You can cut, trim mpegs (it is frame accurate for mpeg) insert chapter points, add menus and then create a video_ts folder. This where your vobs will be.
Read the reviews for TDA that are on this site. It is solid and easy to use.bits -
With p4 3.0 converting for example DV-AVI to MPEG2 8000 CBR (the standard in Studio) takes about 1 hour for 1 hour of video. That's an average.
If you want to see how your machine stacks up against others see this thread. https://www.videohelp.com/forum/viewtopic.php?t=251737 -
thanks capmaster,
yes i have used pinnacle 9 and if i continue ,i've tried it once,it took hours to get just 20 %rendered.
So i thought there is another Software out there which is faster.
the_Rippel
i,m looking at ulead movie factory 3 disc creator,because of importing vob files and ac3 directly anyone has it and what ya think about. -
at all thx for replies,
i,ll play a little with some other programs.
the_Rippel -
I forgot to mention that TDA will convert the vobs in a video_ts folder back into mpegs.
If you are looking for an application that will take a Studio 9 project and do the authoring then I do not think there is such a software application.
You may need to use a different editing software app all together. Ulead Video Studio 8 is one that can do most everything Pinnacle Studio 9 can but it does NOT re-encode compliant mpegs.bits -
Originally Posted by the_Rippel
Try Ulead DVD Movie Factory. You can set the option to have it not reencode compliant files. There are other apps that allow this too, but this one happens to work well for me. It's fast and simple
Fastest way to convert H264 under OS X
By imanta in forum Video ConversionReplies: 1Last Post: 3rd Dec 2010, 12:01 -
What are the fastest video converters available?
By Monroville in forum Video ConversionReplies: 5Last Post: 26th Sep 2010, 05:35 -
Fastest mp3 ripper
By noki in forum AudioReplies: 15Last Post: 9th May 2008, 21:34 -
Fastest Conversion
By ZoNE97 in forum Video ConversionReplies: 13Last Post: 5th Apr 2008, 07:28 -
Fastest MPEG conversion?
By mingul in forum Video ConversionReplies: 2Last Post: 21st Nov 2007, 16:13
