Have installed SVCD2DVD with no problems but when I try and start it up I get the following message.
Mscorlib Error
The process cannot access the file "C:\Programm files\ Badger Soft\SVCD2DVD\mscvp71.dll" because it is being used by another process
Can anyone please help me?
Ok. Do you have the file: msvcp71.dll in your system folder? This is usually c:\windows\system32.
If you do not have msvcp71.dll in your system folder copy it there from the SVCD2DVD folder. Then delete it in the SVCD2DVD folder.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 21:18 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41 -
Error Message
By Perfik in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Jul 2007, 13:45 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 02:16 -
Error Message
By Kallid in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 15th Jun 2007, 21:13
