I have a Samsung DL burner and a swag of software applications but I don't see that any of them support DL burning. Basically I want to create a disc that contains a few hours of various clips, with a menu system.
I have Ulead DVD Workshop 2 (trial) which I think may be the one but I don't have a clue about what I need to change/set to use the DL dvds.
I can make the single-layer discs no problem. Can someone tell me what setup I need and what I need to look out for? Many thanks.
Just author and burn as usual with ulead dvd workshop. It will fix the layer break, i'm not sure if you can select where it will be though.
thanks Baldrick. There are a few conversion templates that need to be selected - these are High Qual, Normal Qual (120mins), Long Play, Extended Play etc. There is seemingly nothing there for 8.7gb discs. Reckon I just use the standard 120min template?
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
3D movie 50GB BD-RE Dual Layer - but will it work ?
By testing1234 in forum DVD & Blu-ray WritersReplies: 14Last Post: 3rd Dec 2011, 20:21 -
Burning 720p Avi. Movie to Dual Layer DVD
By Falco21 in forum Video ConversionReplies: 2Last Post: 28th Feb 2011, 15:06 -
Rip Blu-ray Movie to fit on two dual layer discs
By craigmack55 in forum Blu-ray RippingReplies: 10Last Post: 9th Dec 2010, 23:16 -
Question about Burning an Entire DVD9 Movie to a Dual Layer
By |-Goku-| in forum DVD RippingReplies: 9Last Post: 30th Dec 2007, 19:41
