I downloaded some ".avi.torrent" files and because space will become an issue, I want to put them onto DVD-RW. However, I get errors when I try to do this and Gspot says "Not a valid AVI file". Also, Windows Media Player won't play them unless I open them through the BitTorrent client. What is different about them?
I'm sorry if I haven't supplied enough information.
Sounds like Warez to me. You said the magic word. Bit torrent!!!
No DVD can withstand the power of DVDShrink along with AnyDVD! -
Originally Posted by Melon_Feet1200
I can't see how opening them up in Bit Torrent will enable Media Player to play them. What errors do you get when you try to copy them to a DVDR ?
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
I would got get the kazaa codic pack , and if u have anymore problems i would use G spot. If ur using a bit torrent program i would use Bit commet because u can see the file i had problem similar and i was 3k of the file and it wouldn't play. So make sure the files are 100% done too
Yo!
I guess your second embedded question is why won't it play.
Plop it onto the LATEST version of GSpot & tell us what it says...
Cheers,
AndyWork you bloody thing....
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Common DivX DVD Players AVI Playback problems!
By Baldrick in forum Newbie / General discussionsReplies: 8Last Post: 6th Jun 2013, 09:32 -
DVD to AVI (XviD / DivX) using VirtualDubMod Conversion problems.....
By dabas in forum Video ConversionReplies: 1Last Post: 26th Feb 2010, 08:12 -
File conversion problems AVI to Divx
By kaptainm in forum ffmpegX general discussionReplies: 2Last Post: 10th Aug 2008, 19:21 -
Tmpgenc problems with divx avi's, encoder suggestions?
By kitykat_2004 in forum Video ConversionReplies: 1Last Post: 26th May 2008, 01:35
