Hey ppl,
I got sum NTSC DVDs which I wanna convert to PAL and keep all the menu's etc. ( i have not got any NTSC compatible TVs either or it would b a peace of cake)
For normal back up's I just rip with dvddecrypter, shrink it with DVD Shrink and then burn it again with DVD decrypter.
Any suggestions would be great.
Thanx
You need to use an editor to transcode to PAL. It has a different resolution that NTSC. Once done you then need to framerate convert from 29.97 fps to 25.
Some editors do this at the same time as transcoding and some require a separate step.
Then author
There's a program called NuMenu4U at doom9.org that will automatically convert menu's NTSC to PAL and vise versa. It requires Sonic Screenist
though. Hope this helps -
thanx for the help, i will check it out, sorry for not posting till now, i expected replies to be sent to my email when i receive any.
Navi95
DVD PAL to NTSC or NTSC to PAL DVD Conversion
By Baldrick in forum DVD RippingReplies: 21Last Post: 12th Apr 2016, 18:30 -
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30
