what is the best methode to get subtitles into the movie.
thanx!
I use the guide at:
http://www.flexion.org/video/DVDConv/DVD2AVI/
to rip anime DVDs and make VCDs with japanese audio and english subtitles. There's a lot of steps, but it's pretty easy and has always worked. The other choice is to use FLASKMpeg (but this program seems to have problems on my machine). There's a guide to using Flask if you look under under the 'DVD RIP' section to your left:
http://www.vcdhelp.com/dvdtovcdflask.htm -
With subtitles, FlaskMPEG is definitely easier. Make sure you've either got the latest preview version of v0.594.
Also, if you are using SmartRipper, rip in "FILE MODE" not "MOVIE MODE".
Regards.
Michael Tam
w: Morsels of Evidence -
VobSub is a nice plug-in for VirtualDub that works great for subtitles. I've made several SVCDs with it.
Subtitle Workshop - not creating subtitle at current time location
By botjocrow in forum SubtitleReplies: 0Last Post: 14th May 2011, 03:09 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 11:25 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 17:03 -
Best DV archiving methode?
By mkrve in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 6th Feb 2010, 15:31 -
Converting SRT or SUB subtitle files as a Subtitle Track for DVDs...
By soneman in forum Video ConversionReplies: 3Last Post: 22nd Feb 2008, 14:17
