Some people say to download mmc 8.9, not 9.x versions.
What's the best mmc & driver version to use the Ati all in wonder rage 128 on my Windows Xp professional to have best capture quality?
thkss![]()
Results 1 to 23 of 23
You're limited to 7.2
this is a pic of th card:
http://img195.exs.cx/img195/116/ati8le.jpg
is it ati pro 128? or 128? -
If it is 128 PRO (Theatre chip), then the most you can do right now (that I am aware of) is to hack it for ATI MMC 8.7, which was the most stable recent release. It's a rather lengthy process, and requires custom files.
can you wach this pic to seee if it's an ati pro?
how can i download mmc 8.7? how install it? thanks!! -
this link now should work...
http://img69.exs.cx/img69/927/ati0yj.jpg
thks
That's the AGP 128 PRO.
thks...last question....how can i download mmc 8.7? how install it?
TAHNKS you are very very helpful!
For WindowsXP version. go here:
http://www.ati.com/support/products/radeonwinxppreviousdrivers.html
For Win98 version, go here:
http://www.ati.com/support/products/radeonwinmepreviousdrivers.html
For hacks, I don't know. -
just thought I'd throw my 2 cents in here...
I have the exact same card, running under XP Home. I run MMC 7.7 to capture all the time, and the drivers that are running the card are the generic ones that came with XP. I have tried almost every combination of drivers, control panels, catalysts, and everything. My system just doesn't like anything but XP ones...just a thought
mastersmurfie -
I'm confudsed
I haven't yet put the ATI card in my computer becouse I've buyed from a private person and it has been shipped yesterday... so I want to say what version to install (driver, mmc, catalyst...) on my Windows XP Prof SP2 to work the AIW properly.
It's the first clean installation of the card and I don't want to wrong.
THANK YOU
Just to increase your confusion (as mine) this is an interesting link:
http://www.rage3d.com/board/showthread.php?t=33787490
where you can find information about installing MMC on AIW 128 Pro.
I would advice you to save a partition image, using Ghost or something similar, before starting anything.
You should be in the right moment to do it and test various MMC version, eventually recovering a clean installation.
Hope it helps
Riccardo -
Ciao Riccardo anch'io sono italiano, precisamente da Padova, grazie per l'aiuto!!!
i just intall an aiw 128 pro agp 32m yesterday, in a fresh xp pro os,
this is the name of the files of the drives i use, and the mmc to
driver wxpr1286133279.exe
mmc (w/o dvd player) MMC72noDVD.exe
dvd player program dvd50.exe
i download all the three programs from ww.ati.com
and it works perfect
you can find the drivers in the ATI RAGE 128 pro AIW, from the
ati web page
i hope this works 4 u 2
arriverderci, bambino -
thanks but I want to install MMC 8.7...
I'm searching for the right combination of catalyst, driver ecc...
any
I have the exact same card running on XP pro and I can only get the MMC 7.7 to work with my captures...the Library portion does not work with 7.7 only with 7.6.
I have tried all the MMC 8.x versions and the installer just stops when it gets to the "Preparing to Install" window....and then just disappears....strange. -
Have seen some claims of running 8.x on this card (I have 2 of them) but no verification on anything higher than 7.7. SFAIK most enhancements past 8.1 were to Easyview, and support for PCM audio cap and Divx, other codecs.
Used Catalyst drivers from ATI and their MMC and control panel, also see instructions at rage3d.com. Note the directions for doing removal after a failed installation, following these could save you a world of hurt. -
Many forums mention using MMC 8.7 as the minimum for good quality captures - does the video quality actually improve over the 7.7 version? I am having ZERO problems capturing with 7.7 and I won't even bother upgrading if it doesn't buy me much....any suggestions.
7.7 is fine ... but 8.7 has more features
THis guy must be alivin in Roma, Italian. Clean install, make a mistake. Use ATI's driver removal tools for a clean un-install.
Is it true that the MMC 8.7 version allows you to capture the same good quality using a lower video bitrate and still maintain good quality.
This is what I heard on another post. Is this true? I guess my question all comes down to video quality of the captured mpeg file. My goal, and probably eveyone's goal, is to maintain as close as possible to the original source quality - that's it - don't care about features/goodies/etc - just good video quality. That being said - does anyone know if there is a difference between 7.7 and 8.7 ??
Thanks. -
8.x have Videosoap and generally, the higher the version the better the quality, though 7.7 was a MAJOR improvement over older versions.
However, if you don't care about disk space, and only about quality, simply use the highest bitrate that you can use (such as 9Mbps).
RAGE PC ending disappointment **Spoilers**
By retroborg in forum Off topicReplies: 1Last Post: 2nd Jan 2012, 10:06 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 21:53 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 16:36 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 02:24 -
Anyone using MMC with X800XL VIVO-only (no TV tuner or AIW) for capture?
By palouse in forum Capturing and VCRReplies: 4Last Post: 15th Aug 2007, 03:28
