Can someone tell me what I'm doing wrong?
test forum
https://www.videohelp.com/forum/viewtopic.php?t=255809
wont work with caps or underscores. Should say that, but doesn't
Thanks cappy
Results 1 to 9 of 9
I don't understand what you're trying to do. Upload a zip file? Or just link it?
Ah...
No caps (no listed)
No underscores (not listed) -
templates for PS in the media forum
No caps, No spaces, No underlines and not all file
name extensions supported, max filesize 2mb.
So Zip it :P -
so it should say that don't ya thinkOriginally Posted by offline
stiltman,
You're not asking for some kind of noob proof system
are you ?
Not really, but if you're going to post a note by it in the first place, might as well make it right. Don't ya thinkOriginally Posted by offline
Kinda like this:
Type filename.zip in your post where the file-link should be. Max file size is 2 MB.
Note! Replace filename.zip with the file name of the file and don't have any spaces in the filename. Hey newbie, don't use caps or underscores either! Oh, and Don't use the Preview if you are uploading files because it will just fock everything up.
not move the file tmp dir to upload folder
By velayudham in forum ffmpegX general discussionReplies: 2Last Post: 19th Jan 2012, 17:32 -
Does zipped video file take less time to upload than unzipped file does?
By coody in forum Video Streaming DownloadingReplies: 3Last Post: 12th May 2011, 10:22 -
FLV file upload to YouTube Failed
By rishting in forum Newbie / General discussionsReplies: 6Last Post: 4th Feb 2010, 09:14 -
Can't upload or convert .FLV file
By fisico23 in forum Video ConversionReplies: 2Last Post: 23rd Jun 2008, 20:58 -
final cut file to upload onto blip
By marinebc11 in forum MacReplies: 1Last Post: 1st May 2008, 10:13
