[ url]118mm22mm_Template.psd[ /url]
edit
[ url]118mm22mm_Template.zip[ /url]
edit
[ url=118mm22mm_Template.zip]118mm22mm_Template.zip[ /url]
Results 1 to 14 of 14
What the heck am I doing wrong?
trying to find the path, just added the jpg extension
[ img]118mm22mm_Template.psd.jpg[ /img]
Dang it!
No capitals or spaces in the file name or between the tags and the file name.
no capitals too?Note! Replace filename.zip with the file name of the file and don't have any spaces in the filename. Don't use the Preview if you are uploading files.
118mm22mm_template.psd
118mm22mm_template.psd -
118mm22mm_template.zip
118mm22mm_template.zip -
template.zip
template.zip -
No underscores either
Might want to say that in the note too -
try a psd file this time
118mm22mm.psd
118mm22mm.psd -
cool
where's an option for it anyway, is /exe/ possible to be uploaded/ and what are the securities, antiviruses scans etc malware nooo
not move the file tmp dir to upload folder
By velayudham in forum ffmpegX general discussionReplies: 2Last Post: 19th Jan 2012, 18:32 -
Does zipped video file take less time to upload than unzipped file does?
By coody in forum Video Streaming DownloadingReplies: 3Last Post: 12th May 2011, 11:22 -
FLV file upload to YouTube Failed
By rishting in forum Newbie / General discussionsReplies: 6Last Post: 4th Feb 2010, 10:14 -
Can't upload or convert .FLV file
By fisico23 in forum Video ConversionReplies: 2Last Post: 23rd Jun 2008, 21:58 -
final cut file to upload onto blip
By marinebc11 in forum MacReplies: 1Last Post: 1st May 2008, 11:13
