I bought a new sound card replacing my existing sound blaster card. The Sound Blaster Live i bought only has 1 AUX-In connection. As in my old sound card hade 3 (AUX-IN, CD-IN, TAD). I have my cd-rw in 1 connection, DVD-rw in the AUX-in and there was something plugged in the TAD. So what the hell am i suppose to do?
If you go to the CD/DVD-ROM drive properties and select ENABLE DIGITAL CD AUDIO, you won't need to actually plug it into the soundcard. That's why soundcards don't provide nearly as many inputs as they used to.
the Creative software that came with it sucks, is there an alternatative in playing music? The Creative software wont let me open the equlaizer to adjust anything. I am using Win Media Player which sound better than the Creative. But i am getting static/noise every once in a while during any song i play.
You should mute any input/output you are not using. I get noise interference from the microphone input on my soundcard so I leave it muted.Originally Posted by rubberman
i dont have my mic hooked up. I just have my 3 wires from my speakers hooked up.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 13:02 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 14:44 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
Sound Card Second Post I've Tried Everything
By gyles in forum ComputerReplies: 5Last Post: 15th Sep 2007, 05:32
