I recently purchased Sony's Vegas 5, which has DVD Architect and when I make DVD's, the play, scene selection, etc. buttons appear when I make the DVD, but when I play the DVD (after it burns) in a player, the play buttons are invisible. You can still select the buttons, but they are invisible. How do I fix this?
I have used this product for a while and I have never run across this problem.
When you create the DVD, try playing it (the files in your VIDEO_TS folder) with a software player. Do the buttons appear on it?
I haven't the foggiest idea why your buttons are disappearing. -
I can't find the folder that it says it is putting the temporary DVD files...this might be why the buttons don't appear....I'll try burning a DVD by sending the temp files to another folder
the button settings are on the right of the screen . there are two setting tabs, one for properties, the other for compilations(music). in the properties view, you'll see a button properties option. i usually choose text only because i make multiple music compilations with many buttons. under the "highlight" tab, mine is set to rectangle. with an image, you might have to play with the mask settings. test with an rw .
sony dvd architect ?
By Deter in forum Authoring (DVD)Replies: 7Last Post: 26th Jan 2010, 18:31 -
DVD Architect 5.0
By Mr. Robinson in forum Authoring (DVD)Replies: 1Last Post: 4th Nov 2009, 11:59 -
DVD architect
By romanstopme in forum Newbie / General discussionsReplies: 4Last Post: 7th Apr 2008, 01:57 -
DVD Architect help
By monks19 in forum Authoring (DVD)Replies: 11Last Post: 23rd Aug 2007, 07:46 -
DVD architect
By Abiyad in forum EditingReplies: 1Last Post: 19th May 2007, 09:02
