I have been tring to use various conversion programs. Like DVDx, DVD2AVI,Simple DIVx. When I set up the program and I am ready to encode I get "Illeagal operation" details say invalid page fault often in kernal32.dll.
Got some info off the web that says system resources could be to blame.
Did anyone squirm their way out of this error without format c being involved?
I 'm running windows 98 and norton system doctor shows my resources are OK. I have removed and installed programs and codecs several times.![]()
I usually had to reformat when these types of errors became persistant. Could possibly be bad/failing RAM. Another thing to try is running scandisk and diskdefragmentor.
I have also had, on a few occassions, Norton Disk Doctor... play mad scientist with my win98 installs.
If possible, Get Win2k or XP, and ditch norton. (Opinion based on my Win98/norton experiences)Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
Check your BIOS to see if the CPU settings are correct.
I had the same problem, with every program I opened, recently.
Wiped, re-installed, same, finally checked the BIOS, found that I was somehow o'clocked to the point the machine was unstable, 40 Mhz on the PCI bus, which normally runs at 33.
Reset to 33, all's well, now.
I think this started when I blew a 2400 Athlon, replaced with a 2400 Sempron. They have different actual clock speeds.
RAM is a possibility, though, and I thought it was my prob, swapped out 3 sticks to find the same with all.
Hope this helps. I see you are showing a 1.7 Ghz CPU, AMD or Intel?
Cheers,
George
My DVD backups are "invalid" in Sony Blu ray player
By KeithMckane in forum Authoring (DVD)Replies: 6Last Post: 26th Feb 2010, 15:11 -
TMPGenc DVD "add a note page" ?
By Spassvogel in forum Authoring (DVD)Replies: 0Last Post: 6th Aug 2009, 00:07 -
HCenc "Invalid MPEG-2 Frame rate" error.
By Maikeru-sama in forum Video ConversionReplies: 24Last Post: 8th Jul 2008, 18:09 -
Philips DPV-5992 not recognizing a USB HD - "Input Invalid"
By benvid in forum Newbie / General discussionsReplies: 6Last Post: 21st Jun 2008, 17:02 -
Clonedvd error"invalid block start code"
By demonwarrior in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 05:01
