Hi
I just received a movie in VCD format spliited over two CDs
I yet not have a proper dvdplayer but I use PS2 to watch them
PS does not play VCD so I am wondering if I can reenconde the movie as DVD and what to use to do this if possble at all? Thank you
Results 1 to 12 of 12
Hello,
YES!
https://www.videohelp.com/convert
Look up VCD-DVD.
Many authoring programs like TMPGENC DVD AUTHOR will convert it for you.
Since its on cd now you'll need isobuster to remove the mpg video from the .dat file.
Another way.
https://www.videohelp.com/guides.php?link=727Cheers, Jim
My DVDLab Guides -
I hear Action Replay Max can now play video on the ps2 with their converter.
But easier to just buy a cheap dvd player for $25 that plays vcd. -
It's actually simpler (IMHO) and quicker doing it my way.
Yoda's way works just as well, but takes more steps, and more time.Cheers, Jim
My DVDLab Guides -
VCD-DVD is nice.. fit 7-8 hours of vcd qaulity video on 1 dvd.. but you need to make sure the audio is changed from 44.1khz to 48khz.... I have authored several dvd's like this.. mostly political movies
https://www.videohelp.com/forum/viewtopic.php?t=129786
I'd just drop it into TMPGEnc DVD Author (just like you would any other DVD-compliant file), and it'll do the audio resample automatically for you while it's outputting. Can't get any simpler than that IMHO
If in doubt, Google it. -
Now I hit the snag with TMPGEnc DVD Author
it complains having a roblem with GOP and don't know how to fix this problem
All I did was to extract the tracks with isobuster as track2 but since there were two VCD tracks I decided to rename them in sequence that is 1 and 2
What do I do to change GOP?
thanks -
How best to convert/get rid off VCD/DVD/HDVD9?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jun 2010, 01:17 -
How to convert E-Book in PDF Format to VCD or DVD
By permataharahap in forum Newbie / General discussionsReplies: 2Last Post: 29th Jul 2008, 01:00 -
Playing VCD on Computer or convert to DVD
By corumz in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2008, 06:35 -
Settings to convert WMV to VCD/DVD-playable format?
By pingosimon in forum ffmpegX general discussionReplies: 5Last Post: 16th Jul 2007, 18:53 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
