I've had 2 vcds now that will not play on my Pioneer DV535 but will play fine on the PC.
They look like a standard VCD. I've even run the .dat file through VCDGear and reburnt the Mpeg with Nero, but it still wont play.
I've tried these in another dvdplayer and the same thing??
Why is this and how do I get around it.
Trying to re-encode the Mpeg at the moment to see if that works.
somethis fishy.
are you sure its standard? (size and bitrate)
i dont know about that player but maby it is media problem.
Well, I am the slime from your video.
Oozin' along on your livin'room floor. -
yes it's standard PAL. Ripped off a DVD. If it's not NERO wouldn't burn it.
Stop the Press..
Re-encoded with TMPGEnc and now plays ok
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 11:38 -
Insignia portable DVD player can't play VCDs
By Amuse in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Nov 2007, 20:28 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 12:46 -
How to play a HD clip on my standalone HD player?
By Ingolf in forum DVB / IPTVReplies: 15Last Post: 24th May 2007, 13:43
