    Dec 2003
    Spain
    Hello,
    My mpeg4 standalone player has problems with Xvids depending on the quantity of b-frames used.
    With Gspot beta version I can see if an Xvid has b-frames, but for the moment I haven't found the way to know if has 1 or 2 b-frames.
    Is there a way to know that?
    Thanks in advance.
  2. Member monzie's Avatar
    Nov 2003
    The Village
    I think you mean KEYFRAMES or I FRAMES...this is what players search to....1 or 2=crap....you need A LOT more
    Dec 2003
    Spain
    Thanks for answering.
    I meant B-frames.
    There's an issue with xvid with b-frames that are played jerky by players like Kiss 1000.
    This is more or less the pattern someone found out:
    Xvid, 1 bframes, packed: okay
    Xvid, 1 bframes, not packed: jerky
    Xvid, 2 bframes, packed: okay
    Xvid, 2 bframes, not packed: very jerky
    I'm just doing some tests with that player and my Xvid disks and wanted to know, if possible, which ones fit the 1 bframes category and which ones the 2 bframes.
    I know they have B-vops (b-frames) because Gspot tells me that, but it doesn't tell me if 1 or 2.
    Dec 2003
    Spain
    OK, I found the program.
    Mpeg4 modifier tells the number of consecutive B-Vops.
