My sister has brought from the United States a DVD she and her husband made of their honeymoon. The DVD is in Region 1 and here in Greece we have Region 2.
I want to make a copy of it using my PC but when I inserted the DVD to the drive and started DVD Decrypter it had a lot of read errors because of the different Regions. Is there a program that I can use to change the current Region of my DVD's drive to Region 1 (or free) so that I can make a copy?
My DVD drive is ATAPI 16max
Thanks in advance guys!!!
Results 1 to 11 of 11
What brand of drive is it? Some drives have applications and/or firmware that can change/disable region-coding.
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
Sounds like a drive-region issue to me, Yoda. Know any good apps to disable that?Originally Posted by BlackAdder2TheRescueIf God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
I think that only works for playing DVDs, not copying them, which is his problem.Originally Posted by yoda313
If you have a LITEON, you can use this:
If not, here's some payware that'll do ya.
https://www.videohelp.com/tools?tool=DVD_Region-FreeIf God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
As I stated previously, you may use DVD Genie if you care only for playback.Originally Posted by BlackAdder2TheRescue
Do you know what model writer you have? Examine this list: https://www.videohelp.com/dvdwriters.php?DVDname=MSI&Submit=Search&cdrs=&cdrws=&dvdrs=&...&Search=Search
If yours has the mediatek chipset, you might be able to use this free tool:
George Carlin -
I can't believe a homemade DVD has region protection but you might try DVD region Killer or AnyDVD.
I know I asked my sister about the same thing and she told me her husband somehow did it...I dont know...Originally Posted by MOVIEGEEK
The thing is, when I try to play it, it plays perfectly fine, I have DVDRegionFree+CSS program. The problem appears when Im trying to make an image of the DVD with DVDDecrypter. -
Originally Posted by yoda313If God had intended us not to masturbate he would've made our arms shorter.
George Carlin
DVD exploding inside the drive from a drive exceeding 24x. True?
By snafubaby in forum MediaReplies: 10Last Post: 5th Dec 2010, 19:05 -
Is using a Bluray drive better than a regular DVD drive?
By imfallen_angel in forum DVD RippingReplies: 14Last Post: 20th Mar 2010, 21:49 -
Cannot burn to a DVD disc and DVD RW-drive changed to CD-drive after copy
By coody in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Sep 2009, 05:18 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 19:38 -
Lite-On drive LH-16W1P DVD-DL drive
By snafubaby in forum MediaReplies: 8Last Post: 28th Apr 2008, 16:00
