I have a 411s with firmware FSOH. I have used this same firmware for the past 8 months or so, with no reason to update or change as it has worked for me. Just recently I have tried to copy some DVD's I had taped with my LiteOn 5005 recorder. I was not having any success using DVD Shrink or DVD decrypter, but thought it might have been something with the 5005, as I had read people had been having "some" problems. This morning I tried copying a DVD that we had purchased, to eliminate the 5005 as part of the problem. I used DVD shrink 3.2, and after the "encoding" I selected the "backup", the target and source were as I wanted them, and when I selected to continue, this is the error message I recieved...."DVD Shrink encounted an error and cannot continue, Failed to write file "E.\DVD.VIDEO.ISO".....So does this tell you guys anything I need to check? I have ran so many "spyware" and "virus" programs the past few weeks, I thought perhaps I had deleted some file, that I need for Shrink to work? I also tried to use DVD decrypter, alone, but it failed also(I cannot remember what error message I received). Anybody have any ideas? I would appreciate any help you can render!
thank you,
coadman
Results 1 to 12 of 12
convert your liteon 411 drive to a 811 drive by using the zebra mod. check out the LITEON FORUM at cdfreaks.com people there can help you out.
Originally Posted by budz
coadman -
I converted my 411s to a 811s and downloaded the HSOR firmware. So far, so good, it is working,,now just to find the right reliable media.
coadman -
I upgraded my 401s to the 411 then to the 811. I was kind of worried about reflashing the drive with the 811 latest firmware. Should I?? -
Moving this to DVD Writer forum ...
What advantage is the HSOP over the HSOR? Right now I am using Ritek R03's currantly, until I finish off this stack!(about 50 more to go),,Then Im going to start on some FUJI (TY's).
coadman -
Originally Posted by coadman
Yes, Ive found out my drive likes the +R media better, so that's all I ever purchase.
thanks
coadman
IMGburn 2.5.1 copying problems
By NickiMitch in forum DVD RippingReplies: 1Last Post: 7th Jun 2010, 08:58 -
liteon shm-165h6s problems to spin and detect media
By deejay.2001 in forum DVD & Blu-ray WritersReplies: 0Last Post: 29th Aug 2009, 09:28 -
Problems copying CDs on Mac
By Nilfennasion in forum MacReplies: 3Last Post: 3rd Jul 2009, 08:15 -
Liteon 5001 and HQ mode problems
By oldfart13 in forum DVD & Blu-ray RecordersReplies: 12Last Post: 30th Sep 2007, 23:49 -
Anyone had problems copying Dvd's with HP drives?
By Blumphf in forum DVD & Blu-ray WritersReplies: 53Last Post: 31st May 2007, 20:40
