  1. Ive just started using dvd rebuilder and cce and i keep getting this error
    runtime error "52"
    Bad filename or error
    any help would be appreciated
    Apr 2004
    Miskatonic U
    How have you set it up ?
    Are you using eclcce ?
    Which version of cce are you using ?
    Have you looked at the DVD Rebuilder forum at Doom9 ?
    Read my blog here.
  3. That means that you probably haven't made a good setup...
    Try my installer from www.dvdrebuilder.com
    It will make it easier...
    My oppinions may change, but not the fact that I am right!
    www.rockassoftware.pt.vu
    DAudioK => https://forum.videohelp.com/viewtopic.php?t=306886
    DVD Rebuilder
    http://dvd-rb.dvd2go.org
    http://www.jdobbs.com
