  1. hi everyone ive used this program in the past without any problems but since i have to reformat my pc and installed it again i cant get it to work svcd2dvd1.5 works fine but 2.0 isnt working at all i cant add anything to start it with geting the message below PLEASE HELP as i use this program 24/7
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.IO.FileLoadException: Strong name validation failed for assembly 'SVCD2DVDLib'.
    File name: "SVCD2DVDLib"
    at x3284ccece41ee22b.xece14591aa1abb99..ctor(Guid xe423f530b92aa05c, String xd168ac2ed64c4662)
    at x3284ccece41ee22b.xece14591aa1abb99..ctor(String xd168ac2ed64c4662)
    at x3284ccece41ee22b.xe4d2667f3c3c2e1b.xca3a7a432977a ec0(Array x19218ffab70283ef)
    at x3284ccece41ee22b.xe4d2667f3c3c2e1b.x32086c1a80bfe 175(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
    at DevComponents.DotNetBar.BaseItem.RaiseClick()
    at DevComponents.DotNetBar.BaseItem.InternalMouseUp(M ouseEventArgs objArg)
    at DevComponents.DotNetBar.PopupItem.InternalMouseUp( MouseEventArgs objArg)
    at DevComponents.DotNetBar.ButtonItem.InternalMouseUp (MouseEventArgs objArg)
    at DevComponents.DotNetBar.GenericItemContainer.Inter nalMouseUp(MouseEventArgs objArg)
    at DevComponents.DotNetBar.Bar.OnMouseUp(MouseEventAr gs e)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at DevComponents.DotNetBar.Bar.WndProc(Message& m)
    at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
    at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    === Pre-bind state information ===
    LOG: DisplayName = SVCD2DVDLib, Version=1.0.1839.37055, Culture=neutral, PublicKeyToken=a1048512262ee648
    (Fully-specified)
    LOG: Appbase = C:\Program Files\BadgerSoft\SVCD2DVD 2 BETA\
    LOG: Initial PrivatePath = NULL
    Calling assembly : SVCD2DVD, Version=2.0.1843.19197, Culture=neutral, PublicKeyToken=a1048512262ee648.
    LOG: Publisher policy file is not found.
    LOG: Host configuration file not found.
    LOG: Using machine configuration file from C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\confi g\machine.config.
    LOG: Post-policy reference: SVCD2DVDLib, Version=1.0.1839.37055, Culture=neutral, PublicKeyToken=a1048512262ee648
    LOG: Attempting download of new URL file:///C:/Program Files/BadgerSoft/SVCD2DVD 2 BETA/SVCD2DVDLib.DLL.
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    SVCD2DVD
    Assembly Version: 2.0.1843.19197
    Win32 Version: 2.0.1843.19197
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/SVCD2DVD.exe
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    Assembly Version: 4.6.0.0
    Win32 Version: 4.6.0.0
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/DevComponents.DotNetBar.DLL
    AxInterop.CodeLock
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/AxInterop.CodeLock.DLL
    System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
    Accessibility
    CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
    Interop.CodeLock
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/Interop.CodeLock.DLL
    Interop.QuartzTypeLib
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/Interop.QuartzTypeLib.DLL
    System.Design
    CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
    ************** JIT Debugging **************
    To enable just in time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
    i have all codecs installed exactly as i did the first time before i had to reformat
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    SVCD2DVDLib.DLL has got corrupt somehow. Can zip up & email the file to me so i can see what it going on?
  3. hi ChrissyBoy i have sent you email regarding the file you asked for i hope it helps as i still cannot get it to let me add any files
    but still hey may have its tweaks but its the best program ive used ,been using 1.5 it for almost 2 yrs now and now 2.0 rocks
    mark220478
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Mmm. Can you resend it please? Got nothing this end yet....
  5. I have same problem too!
  6. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    What version are you running?
  7. I know the problem was because when I set Regional and Language ->Advanced->Language for non-Unicode programs to non-English, The SVCD2DVD RC2 will run few secound then just close and nothing came out.
    Then try to set back to English (United States), and the program run's well!
    But I really need set non_Unicode programs on my computer, Could you solve this problem!
  8. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Well 'SVCD2DVDLib' will be dropped in the next release so maybe the problem will be fixed as a result.
