Hi all,
I was wondering whether its possible to regain some qualities out of a divx format movie into somehow a dvd or any kind with a better quality. Can anyone tell me which program(s) I sholud use and is there a guide on how to do it.
Thanks guys
You can never re-gain quality that is lost. However, you can use some filtering in Virtualdub that may improve the look of the video and remove some noise, etc. There are a lot of VD filters out there. There are some guides here for VD and if you do a Google search for 'Virtualdub filters' you will find a lot more information.
Yep, what redwudz said.
But generally, unless this is **REALLY** important, its not usually worth the effort.There are 10 kinds of people in this world. Those that understand binary... -
Hello,
Yep it's always best to start from the ORIGINAL source as converting loses the quality.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
OpenDivx4 to Divx without quality loss?
By bizzybody in forum Video ConversionReplies: 2Last Post: 28th Mar 2009, 13:21 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 18:59 -
Rip DVD to DIVX with the same quality
By jujuandhuhu in forum DVD RippingReplies: 20Last Post: 12th Apr 2008, 13:43 -
Divx to DVD and quality loss
By marioval in forum Authoring (DVD)Replies: 5Last Post: 21st Jan 2008, 16:05 -
Better quality DivX encodings???
By smt_88 in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2007, 00:13
