Hi all,
I have a movie with resolution 352x272 and I want to resize it to 352x288 (standard PAL resolution). I don't want to do this by encoding this once again (quality, time). So is there possibility to add borders (8 pixels up and 8 pixels down)? And if there is what software is able to do this. I would prefer freeware (for example TMPGEnc). But no encoding, just to add borders.
Thanks in advance!
Br,
-= EpiMann =-
If you want to add borders you have to reencode. There is no other way.
Allright, I'm just a little bit suprised by this. You could think that this is easily done with any software on market and I cannot see why this has to be done only by re-encoding the movie. (=stupid me)
But anyway ... thanks for your quick response! =)
(gonna spend next 8 hours re-encoding this mpeg)
Cheers,
EpiMann
Add borders to MKV without reencoding?
By squadjot in forum Video ConversionReplies: 3Last Post: 16th Nov 2010, 13:53 -
How do I join avis of different dimensions together? Or add borders?
By thedarkness in forum Newbie / General discussionsReplies: 9Last Post: 24th Jul 2010, 18:19 -
any free tools to resize/clip mpg2 and add black borders?
By extent in forum EditingReplies: 4Last Post: 16th Dec 2009, 17:23 -
How to add clips MPEG together
By avz10 in forum Newbie / General discussionsReplies: 0Last Post: 15th Aug 2009, 00:47 -
Easy way to add borders to h264 video?
By cbl016 in forum Newbie / General discussionsReplies: 2Last Post: 10th Oct 2008, 02:51
