Hi all:
I need to do a presentation and part of it is to create a dvd containing several movie clips.
Questions:
a) How do I do this, transform the avi files into dvd format and then put them together in one disc.
b) Were can I go to download movie trailers? I went different place in the net but I can play them but could not download them
C) what tools do I need?
I have Decrypter, Dvd Shrink and Nero.
I would really appreciate your help in this!!
You may use TMPGEnc to encode the AVI files to a DVD-compliant MPEG file. You can use TMPGEnc DVD Author to create your DVD along with some simple menus.
Movie trailers are often available on the company website - run a Google search.
I would strongly advise that you read a little bit before posting. The Guides section to your left will help you with everything you need - AVI --> DVD is really very basic and is covered in twenty million different guides. Also, please choose a subject that describes your problem.
If you get stuck at a specific point during your conversion, do a forum search and if it doesn't resolve your problem then post back up here.
Best of luck to you!
Cobra
Forum Moderator
