If I connect my 8mm camcorder to the AV socket on my Sony Mini DV camcorder, then the DV out on the Sony camcorder to my FireWire port on my Mac, I can get pass through on the Sony camcorder and capture the video footage in iMovie by just playing the 8mm camcorder. I am now trying to do the same but with a VHS machine in place of the 8mm camcorder, but I cannot get pass through. I have to record the VHS onto Mini DV tapes and then play these back and capture them in iMovie. I have a task to import 3 full VHS tapes and this will take ages with this two step process and I will also have to patch together all the breaks for each 60 minute DV tape. Any idea why this works with an 8mm camcorder and not with the VCR?
Thanks,
Nick
I don't know which version of iMovie you're using, but I've read posts at Apple Discussions where iMovie HD won't capture video from a low-quality source such as VHS recorded in an extended play mode. So maybe it is the video quality of the source that is the problem here.
I am using iMovie 4.0.1. I will try with a different video tape which is of better quality, but it seems as though the camcorder isn't providing pass through and i cannot think why this would work fro an 8mm camcorder and not VCR.
Ivy Bridge to be up to 199% faster than Sandy Bridge
By deadrats in forum ComputerReplies: 33Last Post: 7th Dec 2011, 13:06 -
JVC mini dv camcorder
By biancoape in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 14th Feb 2010, 09:14 -
pc not recognizing mini dv camcorder
By jbitakis in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 7th Nov 2007, 01:07 -
By jbitakis in forum Capturing and VCRReplies: 2Last Post: 13th Sep 2007, 14:59 -
Hd Mini dv tapes via SD mini DV camcorder
By imptech3 in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 03:11
