Yep..... I hope mines has the DVD+R as Yuden...because the DVD-R were All Taiwan..
Results 1 to 11 of 11
"What It Do"
Huh ????? -
Circuit City has those Verbatim 4x with the annoying digital movie 'reel imprint' design that no one wants anymore :-}
25 for 9.99after rebate
I doubt any of 'em are manufactured in Japan anymore, tho! -
Verbatim has never manufactured any of its 4x media in Japan. Were you talking about the TDKs? If so there should be plenty of TDK 8x +Rs made in Japan (YUDEN000T02) available.
100% sure; I have a spindle myself. Just look for a "Made in Japan" sticker on 8x TDK DVD+R 50 disc spindles. It will be placed on the label over where "Made in Taiwan" is printed, but don't let that bother you any. TDK was probably too lazy to print all new labels for the TY spindles.
If you need any more reassurance:
https://www.videohelp.com/dvdmedia.php?selectmedia=2580#comments
http://club.cdfreaks.com/showthread.php?t=121840 -
I just bought a spindle today at Best Buy, and can confirm it is Yuden.Originally Posted by sssax2003
Code:Media Information Region information N/A not a DVD-VIDEO Media code/Manufacturer ID YUDEN000T02 Media Product Revision Number 00h Format Capacity Blank Disc Free Blocks 405405696 Free Capacity 4.38GB(4.70GB) Book Type DVD+R Media Type DVD+R Manufacturer Rated Speed 8.0x 11080KBps Available Write Descriptor CLV 8.0x 11080KBps Available Write Descriptor CLV 4.0x 5540KBps Available Write Descriptor CLV 2.4x 3324KBps Linear Density Blank Disc Track Density Unknown Number of Layers 1 Complete Media Code 00000000 01 02 00 00 A1 0F 02 00 00 03 00 00 00 26 05 3F .............&.? 00000010 00 00 00 00 00 00 03 59 55 44 45 4E 30 30 30 54 .......YUDEN000T 00000020 30 32 00 38 23 54 37 10 02 4E 72 02 8C 63 16 16 02.8#T7..Nr..c.. 00000030 0B 0B 0A 0A 01 19 1B 0C 0C 0C 0D 01 00 00 00 00 ................ -
Bought 4 packs. Most of them had the made in Japan sticker covered over the Tawian; however, there were Taiwan ones there as well. Excellent deal on Taiyo Uden media. I would prefer the -R so that I can use it w/ my standalone recorder, but for PC burning these are fine.
Yea I got 2 dvd+r's at 2 different bestbuys and they were both TY media. Yea baby!! They burn 12X on my LG burner
*New Mac user*, been PC user 4 life -
Thanks for the heads up!! I just went out and got mine. Awesome media!!!!!!!!
Well I went rushing to Best Buy to get these, but I was informed the Verbatim not the TDK were the ones for $19.99 (someone has since posted an update in another thread mentioning them).
No biggie, I'll go back. But it's a spindle of 50 Verbatim that are 19.99 not TDKs. Those were 39.99 for 50...
P.S.: I did get the super clearance TDK DVD+Rs, 15 for 4.99. Can't beat that.
Cheers,
Victoria -
The TDK sale was last week, that's why you couldn't get them for $19.99
what is wrong with these TDK?
By twister6 in forum MediaReplies: 21Last Post: 26th Feb 2009, 14:50 -
TDK now Imation - updated 10-30
By BiggerJim in forum MediaReplies: 1Last Post: 29th Oct 2008, 17:21 -
TDK DVD+RW format before use
By nobbydadog in forum MediaReplies: 2Last Post: 30th Apr 2008, 09:55 -
Best Buy Verbatim - 50-Pack 16x DVD-R Disc Spindle $12.99
By sknox in forum MediaReplies: 5Last Post: 16th Mar 2008, 21:46 -
What should I do with these TDK's
By Waltj in forum MediaReplies: 6Last Post: 3rd Jun 2007, 00:27
