I just redid my computer & installed AutoGK. I installed v1.6, then upgraded to 1.88. I also installed the latest DVD Decrypter (3.5.2.0) & AC3Filter.
When I run AutoGK, I get the error mentioned. This is the log:
[29/01/2005 9:10:35 PM] AutoGK 1.88b
[29/01/2005 9:10:35 PM] OS: WinXP (5.1.2600).2
[29/01/2005 9:10:35 PM] Job started.
[29/01/2005 9:10:35 PM] Input dir: D:\raiders
[29/01/2005 9:10:35 PM] Output file: D:\Raiders.avi
[29/01/2005 9:10:35 PM] Audio: English
[29/01/2005 9:10:35 PM] Subtitles: English / Normal Captions : Wide
[29/01/2005 9:10:35 PM] Display only forced subtitles.
[29/01/2005 9:10:35 PM] Codec: XviD
[29/01/2005 9:10:35 PM] Target size: 1399Mb
[29/01/2005 9:10:35 PM] Custom audio settings: AC3
[29/01/2005 9:10:35 PM] Started encoding.
[29/01/2005 9:10:35 PM] Demuxing and indexing.
[29/01/2005 9:10:35 PM] Processing file: D:\raiders\VTS_01_0.VOB
[29/01/2005 9:10:35 PM] Processing file: D:\raiders\VTS_01_1.VOB
[29/01/2005 9:10:35 PM] Source aspect ratio: 4:3
[29/01/2005 9:10:35 PM] Source resolution: 720x480
[29/01/2005 9:10:35 PM] Found NTSC source.
[29/01/2005 9:10:35 PM] Analyzing source.
[29/01/2005 9:10:38 PM] Source has percentage of interlacing in motion areas: 0.00
[29/01/2005 9:10:38 PM] Source has percentage of telecined patterns: 0.00
[29/01/2005 9:10:38 PM] Source has percentage of progressive patterns: 0.00
[29/01/2005 9:10:38 PM] Source has percentage of interlaced patterns: 0.00
[29/01/2005 9:10:38 PM] Source is considered to be progressive.
[29/01/2005 9:10:38 PM] Output will contain 2 frames
EXCEPTION: Audio is not found.
[29/01/2005 9:10:38 PM] Job finished. Total time: 2 seconds
I also noticed that the source aspect ratio is 4:3, when it's a widescreen DVD.
I'm running WinXP SP1A on an MSI K7N2 Delta-L with an AMD XP2500+.
Thanks for any help.
I found the problem.
I had originally ripped with the wrong settings & it created all these files like VIDEO_TS.BUP. I erased those, re-ripped & all's well.
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 21:56 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 11:23 -
Exception: Audio is not found [AutoGK]
By corn in forum DVD RippingReplies: 2Last Post: 3rd Sep 2009, 00:57 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 16:42 -
No audio decompressor could be found to decompress the source audio format.
By rocky12 in forum AudioReplies: 3Last Post: 1st Sep 2008, 00:59
