  1. Member rion's Avatar
    Thousand Islands
    I'm confused with the bitrate calculator im using right now.
    bincsoft and mAd bitrate calculators has diferent calculations, where did I go wrong? my inputs are the same with the two softwares.
    can anyone recommend me what bitrate calculator should I use to encode DVD movies?
  3. Member rion's Avatar
    Thousand Islands
    Svcd bitrates are the same with DVD bitrates right?
    fit2cd only mentioned SVCD.
    I'm stil a newbie with encoding these formats
  4. Mod Neophyte redwudz's Avatar
    USA
    Fit2Disc is from the same people and will do DVD. Fitcd is just for cds.
  5. Member rion's Avatar
    Thousand Islands
    ok, Ic. thanks
