what software do you recommend to convert .VOB file or .ISO to avi or mpeg or wmv?
Results 1 to 19 of 19
any1/?
You are in breach of the forum rules and are being issued with a formal warning. PLEASE wait a few days befor bumping a topic.
/ Moderator Baldrick -
I believe he is pointing you to the 'convert' selection in the 'How To' area.Originally Posted by masri
Bingo.Originally Posted by jdw
Slow down. Read the Converting section. If you don't find what you need, then start in the All Guides section. And use forum search.
You agreed to do basic research before posting when you joined. It sounds to me like you are too impatient to do any work on your own. That won't help you get an answer here
wow it would be easier if someone just type a software name wouldnt it instead of all these posts telling me what to do?
Teach a man to fish....
Here's a hint:
V _ _ _ _ _L _ _ _ _ _D v1.5.10 -
It sounds corny, but "Give a man a fish and he eats for a day. Teach him how to fish and he eats for life"Originally Posted by masri
True statement.
If Someone gives you the link, you'll never learn how to find your answers. The next time you need something, you'll just post again asking for help. And some kind soul will help you ...and he'll do the searching you should be doing.
Read the guides .....do a forum search. You'll find what you need, and you'll also find other stuff for future reference when you need it
Exactly. You're only getting a hard time because we want you to learn.
ISOBuster, DVD2AVI, TMPGEnc, Virtualdub, & Windows Movie Maker.Originally Posted by masriIf in doubt, Google it.
thanks to those who posted softwares, thats the helpful part..a person askin for help wants to get this done, not search in a maze
the best way to help someone..is say the software, and the steps to do what is needed.. -
There is a very easy method to change a xxx.VOB file to a xxx.mpg file without even a software.
Simply rename the .VOB to .mpg and that was it.
Do not forget that somehow VOBs are MPGs too.
You have forgot to mention why you want to make your files in mpg??
If you tell us why then maybe we can help you more....-Try again ! Try harder !! .....The Crow (1994) -
hi nobodydies
well mainly i want the AUDIO of the file...in moviemaker, you can import certain files, VOB is not one of it, so i wanted to get the audio software
but also in the future i want to be able to convert a dvd to a smaller sized file
i got VIRTUALDUBMOD, but the output of the file is like 7 gegs, and thats nuts
cant the output file be smaller? -
Let as make a start from the audio....
The easiest method is to separate video from audio, and for that you will need a prog called VobEdit.exe and I think that is very easy to find.
(Here------> http://www.ifoedit.com/ )
When you first start the program you will see a Button in the down left corner that says 'Open'...
Press it once and drive into your folder where your VOBs are.
1....Usually it is enough to open the first VOB only (for example the VTS_01_1.VOB) Double click on it and then......
2....Press the third button the one that says 'Demux'. Once you press this button a new window pops up. In this new window I want from you to make two "hacks":
One in the blank square of the "Demux all Video streams" and one in the sqare of the "Demux all audio streams". And now,
3....Press OK, and a "Save As" pop up will come into play.
Just choose a proper name for your files, press save and you are done !!!
After 5-10 minutes (depending how big is your file and how fast is your CPU ) you will have 2 new files: a .m2v file for your video and a .ac3 file(hopefully) for your audio.
I hope I said enouph for your first steps.-Try again ! Try harder !! .....The Crow (1994)
vob to avi help
By odiedog in forum Video ConversionReplies: 12Last Post: 25th Jan 2009, 15:59 -
For VOB files to AVI, I use avi.net . . Question
By nhbfan12345 in forum DVD RippingReplies: 4Last Post: 11th Sep 2008, 00:02 -
VOB to AVI?
By fabpozzi in forum Video ConversionReplies: 3Last Post: 5th Sep 2008, 07:21 -
vob to avi
By Johnnylee_hang in forum DVD RippingReplies: 4Last Post: 27th Nov 2007, 15:25 -
VOB to AVI back to VOB
By fatla00 in forum Authoring (DVD)Replies: 23Last Post: 11th Oct 2007, 04:28
