Hi Guys,
I just wanted some help with regards to the DVD Backup without having 8GB free (http://www.vcdhelp.com/dvdbackup.htm) when u go down to pic5 ie. where it says click on "Plug Settings" after installing the plugins as explained in all the points. The next Screen PIC6 does not show up on my pc.
Have i done anything wrong or any help would be gr8.
Results 1 to 9 of 9
Hi,
I'm the creator of that guide. On my computer the images turn up properly. Try right clicking where the pic should be and select Show Picture. If it still doesn't turn up reply to this.
Thanks,
Dhruv -
Hi Dhruv,
I am not talking about the pictures not showing up on the screen. but i am talking about the Software. It does not do as shown in the images is wwhat i meant
. I hope u get what i mean.
thanks -
Oh ok I get what you mean!
So you can get to the Output Settings but when you click Plug Settings the next screen doesn't come up. Make sure you've selected Video Server under Premiere Plugin Encoder in the Output Settings and then click Plug Settings. Hope this helps,
Dhruv
<font size=-1>[ This Message was edited by: Dhruv on 2001-12-06 02:44:16 ]</font> -
Thanks a ton Dhruv..it works fine now.
Just one final question.Does this kind of ripping produce exact effect..like what i mean is...last time i tried ripping a DVD using DVDDecrypter & TMPGENc there was a delay in the video & audio. Will i have any problems of this sort with your technique.
But anyways thks again. -
You're welcome pats!
I haven't had any audio/video sync problems using this method. But incase you do, you don't have to reencode you can just use my audio/video sync guide to make fix the delay: Its located here
Thanks,
Dhruv -
Hey Dhruv,
now the problem is that the DVDx is not ripping the entire CD. Its just ripping the 1st IFo file. I dont know what to do more.
thanks
When you go to File>Open DVD, make sure you select the title with the longest time, as that will be your main movie and not the special features on the disc.
I only dream in black & white...
MSN: paschendale@gmail.com -
I have no problem with audio and video, but how do I sync the subtitle with audio? My system is Duron 800, 576 MB RAM, 40GB ultra 66 HD, and a Genius SoundMaker Live sound card (I suppose it is the problem, because ATI diagnostics reports a clock stability below required to play DVD).
Frederico Porto.
P.S. please send answer to fbporto@icqmail.com, ok?
Probelm with DVDx 4.0
By vevdare in forum DVD RippingReplies: 0Last Post: 13th Dec 2011, 22:57 -
DVDx 4.0 is now available for Mac OS X users!
By Starbuck2010 in forum MacReplies: 19Last Post: 23rd Jun 2011, 10:55 -
New DVDx 2.20 release is out!
By Jim@labDV.com in forum Latest Video NewsReplies: 3Last Post: 16th Jun 2009, 01:53 -
New DVDx InfoTool is out
By Jim@labDV.com in forum Latest Video NewsReplies: 0Last Post: 22nd Dec 2007, 08:32 -
Error in DVDx?
By php111 in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 14:17
