Windows XP Pro is stuck at the windows xp boot screen, The scrolling line goes than stops than goes than stops. I can boot in safe mode but i see no hardware conflicts. System restore doesnt help. any ideas?
Might be a video prob if you can boot in Safe but not in Normal.
Have you tried VGA mode? It usually lists what it's loading so you may be able to pinpoint what's crashing it.
Nothing can stop me now, 'cause I don't care anymore. -
Start in Safe Mode, right click on your C: Drive, and choose the "check now" button under "tools". It will probably tell you to restart to run CHKDSK, so reboot in regular mode. The Chkdsk can take a long time in this case. Let it all run - give it up to 1 hr to boot. Seriously.
Then it is a driver issue.Originally Posted by rubberman
You should check for an updated driver for the nic card.
Intensity Pro firmware update problem on windows 7 pro 64Bit
By ulva in forum EditingReplies: 1Last Post: 5th Oct 2011, 07:00 -
VOB2MPG Pro / Win 7 Pro 64-bit Service Pack 1 Problem?
By Rich_A in forum SVCD2DVD & VOB2MPGReplies: 21Last Post: 2nd May 2011, 15:06 -
Corel VideoStudio Pro X3 and ATI TV Tuner Pro 650 Card Compatibility
By waldodiodio in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2010, 12:41 -
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 13:50 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 16:27
