Hi,
I have a Laserdisc I must have put away without realizing I had scratched it! Naturally, when I was in the middle of capturing it, I found the 4min trouble spot.Does ANYONE have any ideas how to fix a scratched laserdisc? This is way OOP and I really hate to toss it without capturing it.
Thanks in advance.
Results 1 to 10 of 10
Search Google groups (usenet), specifically in the newsgroup alt.video.laserdiscs. I have vague memories of this being discussed there. Here's a direct link to the search results: Google search results
Otherwise, visit eBay and find a replacement. Once you redub it you can always go back to eBay.
Originally Posted by phelix
LaserDisc's have a very thick protective layer, so it's possible to minimize the scratch to make it play again. I have used "Brasso" liquid brass polish sold at hardware stores to do this. It MUST be "Brasso" brand and some other type (about $4.50 at our local Ace Hardware). Use a soft cloth, not a paper towel, buff some on the scratch, let dry, remove with another soft cloth. You may have to repeat this several time depending on how deep the damage is. This method also works on DVD's CD's etc. although on DVD's you can't repeat it more than a few times.
Hope This Helps. -
Originally Posted by Blazey
Seriously, you might be surprised at what you can find on e-Bay. What Laserdic are you trying to restore? Just in case a good polishing doesn't fix it.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
Originally Posted by drjtech
Quite a number of the old non abrasive car polishes used to work, not just Brasso. My bud used to swear by Simonize. Check the old Google groups. Also when you spread it on, don't do a circular motion, but spread it out from the center in straight strokes. It seems to work better that way. Perhaps the DVD repair cloths work the same way. I used to use those for discs that Disc Doctor couldn't repair as the scratches were too deep. Fellowes among others work for those scratched discs...
You could even use toothpaste..... Works wonders on scratched watch faces.
Note: I haven't personally tried it on disc but it's the same concept. -
I've done toothpaste on CDs. It works, sort of.
scratched discs
By avextraxjp in forum Newbie / General discussionsReplies: 2Last Post: 13th Feb 2009, 17:42 -
How can I recover a scratched dvd/
By wan2no in forum Newbie / General discussionsReplies: 2Last Post: 17th May 2008, 02:48 -
Recovering scratched audio CD
By Des in forum AudioReplies: 11Last Post: 31st Mar 2008, 07:54 -
how to copy the contents from a scratched vcd
By sumeshkri in forum Authoring (VCD/SVCD)Replies: 36Last Post: 28th Dec 2007, 02:03 -
What player for scratched DVD's?
By mad_max911 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 21st Sep 2007, 09:43
