  1. Member ribac's Avatar
    Czech republic
    Hi!
    I have a question.Just tried switched menu in DVD-Lab.Everything looks nice,only what bothers me,here is my situation.
    I have menu with 6 submenus.Each submenu has own picture next to it.When I click on submenu picture changes,but I have to click one more time to get to the movie part.
    Is there any way I can do it with one click??like with mouse I slide around the submenu,automatically picture changes,click on it and be in part I want??
    Another question.Say I have Movie1 long for 2 hours.Now a few seconds before the end I want to fade out the original audio and start to fade in new audio.At the same time I want to start another VGM segment with subtitles on it.
    Problem is when I do more than 1 menu and put audio for each menu,always when menu changes,the audio stops playing till the new menu is on.
    What I'm trying to say.I want to have like 6 VGM menus but still same audio without any stops,so when menues changes,music still goes on.
    I'm sorry If I made someone confused.But I really need to know this.
    For editing movie is better Premiere or Vegas??
    Thanks to all of you guys.This is great forum.
  2. For submenu changes select Autoplay on the active button, timeout 0 (or whatever delay you want).
    You can't do that with audio.
    Cheers, Jim
    My DVDLab Guides
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You cannot keep audio playing during menu changes. Audio and video are tied together in a single asset e.g. each menu part. When one stops, so does the other.
    Read my blog here.
  4. Member ribac's Avatar
    Czech republic
    Thanks for help guys.
    I still have a problem with switched menu.
    I made one menu and cloned it 3 times so right now I have 4 same menus
    with different still pictures.When I click on one of them picture will change,but I have to click one more time to maske the movie play in exact chapter.
    What I need is to just click once.So when you just narrow through the menues I need the pictures to change and when I click once I need the movie to play.
    I checked Auto-action buttons in each menu and put duration to a/v .
  5. Did you check on the PBC tab?
    You must have Force Activate enabled for the button you want.
    That's what starts it playing after the meu switch.
    Set timeout to something worth while, or there's no point in having a switched menu, if you're not gonna see it because the movie starts.
    Cheers, Jim
    My DVDLab Guides
