Hi, I have browsed through the tutorials and forums, but I still couldn't find the answer to this. I have an avi and a ssa file, and I want to put them together. I just want the product as an avi file that can then be played on a divx/dvd player. If I do this with VobSub, it would not work because you would need VobSub to play it, and my dvd player doesn't support that. I know that there is a way for me to do this if I were to make a vcd (frameserve), but I don't want to jeapardize the quality. So is there a way for me to do put permanent subtitles on an avi file without using VobSub or ffdShow?
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
I did that before, but if I were to do that, I must select "Full Processing Mode" which would take forever, and I don't want to frameserve it. If I selected direct stream copy, that filter option would be disabled. Is there any other way?
You must use full processing and reconvert the avi divx, be sure to choose file->compression divx also.
Thanks a lot, I got it to work.
I also have this mkv file, and when I opened it with virtualdubmod, it says something about a variable bitrate. When I tried extracting the sound files, the progress windows flashed for like a second and then went off, meaning that it's done. When I tried to open the sound file, it doesn't play anything. I also tried using MkvEGUI to try to extract the sound files, but they came out to be longer than the original files (extra minutes) How can I extract a sound file that has the correct length from that mkv file?
permanent subtitles on .wmv
By croarta in forum SubtitleReplies: 0Last Post: 4th Dec 2011, 09:09 -
Permanent subtitles with VirtualDubMod
By Jomapil in forum SubtitleReplies: 4Last Post: 8th Nov 2009, 04:34 -
Permanent subtitles
By Jomapil in forum SubtitleReplies: 3Last Post: 15th Nov 2008, 04:24 -
Permanent subtitles with TMPGEnc Xpress 4.0
By b00h in forum EditingReplies: 2Last Post: 18th Dec 2007, 14:43 -
Permanent Subtitles with VobSub
By daniscp in forum EditingReplies: 0Last Post: 18th Dec 2007, 08:42
