I have a problem I would love help with. I ripped a purchased pre recorded disc DVD, released last year.
It is about (~12gig). I used both DVD2oneX and Popcorn.
I compressed with both programs down to 4.1gig.
No matter what I do, the results are:
The playback appears to almost do a A/B between a:
clear/not so clear (pixelated) picture, changing every 3-4 seconds.
It only happens after trying to compress this one program. Others work fine so far. I have tried different media, record speeds, etc. on this DVD with the issue but no change.
Ideas?
TIA
12gb on a DVD?
My mistake, u r correct sir(?)!Originally Posted by stiltman
8gig -
DVD Rebuilder is loved by many. Supposed to to a terrific job, although it probably will take some time. Re-Encodes tend to look better than Transcodes, especially if you're compressing by 50%
Compressing 8 Gig to fit on a DVD-5 isn't going to give you great results no matter what you use.Re-Encodes tend to look better than Transcodes, especially if you're compressing by 50%
equals constipationOriginally Posted by hech54
BTW, I would use DVDRB and steal 33% from extras and remove all non-essential audio streams
pixelation during compression
By asiafan in forum Blu-ray RippingReplies: 2Last Post: 26th Feb 2011, 11:29 -
Pixelation Problem
By Renta in forum Newbie / General discussionsReplies: 4Last Post: 12th Jul 2009, 22:46 -
Problem With Compression
By 360Spider in forum EditingReplies: 2Last Post: 22nd Mar 2009, 14:53 -
Problem with Video after compression
By WuPhilly in forum Video ConversionReplies: 3Last Post: 21st May 2008, 09:58 -
Video Problem after compression
By WuPhilly in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2008, 01:20
