  1. When I try to use the new version .When I try to remultiplex and resample I get a box opens up saying FFmpeg.exe has to shut down.
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can you try other assets? Lets try to find out if it is a problem for all files on your PC or just the one particular file. If it is the latter i will take a look at the file to see what is going on.
  3. Now am getting Version: 2.0 RC1
    Type: System.NullReferenceException
    Source: Interop.CodeLock
    Message: Object reference not set to an instance of an object.
    InnerException:
    StackTrace: at CodeLock._Secure.Authenticate(String pass)
    at AxCodeLock.AxSecure.Authenticate(String pass)
    at x3284ccece41ee22b.x210ff09a2516b1a7.x41f470203acc6 a6e()
    at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9 097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
    at System.EventHandler.Invoke(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
    at System.Windows.Forms.Control.set_Visible(Boolean value)
    at System.Windows.Forms.ThreadContext.RunMessageLoopI nner(Int32 reason, ApplicationContext context)
    at System.Windows.Forms.ThreadContext.RunMessageLoop( Int32 reason, ApplicationContext context)
    at System.Windows.Forms.Application.Run(Form mainForm)
    at x3284ccece41ee22b.x210ff09a2516b1a7.xc447809891322 395(String[] xce8d8c7e3c2c2426)
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    If you email me i will give you a new code... That should solve this issue.
