OK, I have had a brief look about this, but can't a solution for DVDauthor.
I have a DVD folder that works fine under using PowerDVD, now I want to burn to DVD with TMPGEnc DVD Author, when I select burn it prompts a message saying 'The provided folders's structure cannot be accepted by a DVD'. The only difference I can see compared to my other folder is this file. I can add the files and re author, but wondered if there was another ways round this.
Kind regards, Mark
There is no such file as VIDEO_TS.VOB, you should have VIDEO_TS.IFO and .BUP but not .VOB. As the .BUP file is a backup of the .IFO file, try copying that one and renaming it. See What is DVD at the top left to see what the file structure should be and compare it with what you have.
Well I have such a file in all my DVD folders under VIDEO_TS, as well as the two you mention. Anyway I tried copying the mentioned .VOB and it made no difference. I still get the message.
hi
did you extract the dvd files to your hard drive.i also had a similar problem too but i used dvd decrypter to extract the files then.i then downloaded clone dvd and used it to extract the dvd.it then worked fine.
White Fields in Premiere Pro exported video, problem doesn't exist in VLC
By austin8159 in forum Video ConversionReplies: 1Last Post: 10th Aug 2011, 20:50 -
FAVC - Missing VIDEO_TS.bup, VTS_01_0, VTS_01_0.BUP, VIDEO_TS (.vob)
By Brent.M in forum Newbie / General discussionsReplies: 14Last Post: 8th Feb 2008, 08:47 -
dvdauthor problem "chapter doesn't exist"
By ecc in forum Authoring (DVD)Replies: 2Last Post: 28th Jan 2008, 09:54 -
Missing VIDEO_TS.VOB and all VTS_xx_0.VOB
By PietjePuk314 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 18:44 -
Changed Names/Locations - Now "Failed to Load; file doesn't exist
By jeffc4442 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 22nd Sep 2007, 02:10
