Hi I would like to buy a bt878 capture card and use PowerVCR II to capture in real time in SVCD format or in CVD format...
I have a AMD Duron 750 MHz, 512 SDRAM, HD 20GB 7200RPM ATA-66..
...can I do it?????
thanks again![]()
It is been a long time since I used a machine so slow, so I could be wrong, I am afraid that many frames will be dropped during capture.
Get a faster processor, and just in case a bigger hard disk.No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. .. -
You would probably be able to capture to avi and then encode to SVCD compliant mpeg. But you'll need to wait an awfully long time for the encode to happen!
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
