  1. only_emo_kid
    Guest
    while running without a paddle thru dvdshrink i noticed there is a video commentary over top of the movie in certain images.. (while it was analyzing) will this be on the final product? and if so, how can i remove it before i run it thru dvd shrink? or whut? Thanks
  2. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    are you doing a full disc copy?
    DVDShrink will just be going directly through the files on the DVD and not the way they will play. Maybe it's a multi PGC DVD so you won't see the commentary parts unless you select them from the menu. If you did a movie only you should make sure that uncombine linked titles is selected
  3. only_emo_kid
    Guest
    yes, full disk maybe so i'll burn it and see....
