hi
i recently went to capture (like i normally do: ulead videostudio 7, with Picvideo MJPEG codec set on 19) but lately in ulead, i cannot 'configure' any of the Picvideo MJPEG codecs and when i go to capture - the message, "Ulead VideoStudio cannot add this codec into the DirectShow capture plug-in. Please select another codec" if i use anyother program to capture it is fine, but Ulead was the only program that worked for me to capture 640x480 with my ATI TV Wonder Pro.
Any ideas what could have happened? or to fix it?
Thanks...
First thing I always suggest for any errors is to update your software if you haven't already done so.
Are you selecting the picvideo mjpeg codec and not the picvideo lossless jpeg codec? The first one is the one you can configure. Did you do anything before this stared to happen? Install a codec pack.... You could re-install picvideo.
ULead VideoStudio 9 Burning Error
By pcork23 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jan 2011, 09:39 -
help with Ulead videoStudio?
By wamit in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2009, 08:27 -
ULEAD VideoStudio trim
By dcmoser1952 in forum EditingReplies: 3Last Post: 24th Feb 2009, 14:43 -
Ulead VideoStudio 11 on Vista
By run1492 in forum Authoring (DVD)Replies: 2Last Post: 10th Jul 2007, 17:21 -
Audio problems with Ulead VideoStudio 8
By beanosirra in forum Newbie / General discussionsReplies: 4Last Post: 14th Jun 2007, 09:35
