Hi,
I was wondering if there is an easy way I could set all my folders on my computer to Auto Arrange by Name, and for it to be able to remember it next time I went into that particular folder.
My only other option is to go to: Right Click--->Arrange Icons By:--->Auto Arrange and that would just be a waste to do one by one (I have a lot of folders!)
You don't say what Operating System you are running - I'll assume Windows XP or 2000.
Just call up the 'My Computer' window and set 'Arrange by Name'.
Then using the 'My Computer' window, click on 'Tools'-> 'Folder Options' and select the 'View' tab.
In the 'Advanced settings' list make sure that 'Remember each folder's view setting' is ticked.
Then click on the 'Reset All Folders' buttons to clear the settings.
Then click on the 'Apply to All Folders' button to set all of them to the same value as the 'My Computer' window.
That should do the job
and this setting can still be over-ridden for individual folders if required.
thanks bunyip
sorry i didn't mention it was XP - mybad! I appreciate it though! Thanks again
-heckler
How to disable auto-arrange in windows 7 folders
By johns0 in forum ComputerReplies: 0Last Post: 17th Nov 2010, 20:17 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 08:59 -
dvdr auto arrange
By JekylHyde in forum ComputerReplies: 6Last Post: 2nd Dec 2009, 08:34 -
How arrange folders when external storage connected to the USB of DVP
By barbazuk in forum DVD & Blu-ray PlayersReplies: 0Last Post: 23rd Jul 2009, 00:47 -
Is it possible to re-arrange right click
By mn072065 in forum ComputerReplies: 2Last Post: 11th Jun 2009, 22:20
