Hi...
I am having a problem with 2 dvd's (2 disc set).
When I try to decrypt them I immediately get an error that says:
Failed to patch file!
E\ and the name of the file
Reason: Invalid IFO/BUP
Then I press OK and it continues the decrypting process. But when I go to burn the disc it either freezes or errors and won't burn completely.
Any ideas how I can get around this???
Thanks!
What version of DVD Decryptor are you using and have you updated it to the latest and greatest version??? 3.5.2.0 I believe is the most current version out there.
Yes I have the most current version. I always update when there are new ones released. I have tried using DVD shrink with these discs and still have problems.... so I don't know what to do.
I've just moved you to the General forum, but it's a tough one to place.
DVD Decrypter error:Failed to set data for "DVDDecrypterPlayMovieOnArr
By rachelsmiley in forum DVD RippingReplies: 17Last Post: 22nd Dec 2017, 12:40 -
DVD Decrypter error
By turbochargedRS in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 20:08 -
i/o error in DVD Decrypter
By msdker in forum Newbie / General discussionsReplies: 18Last Post: 20th Dec 2007, 23:03 -
DVD Decrypter error
By tRAVALO in forum DVD & Blu-ray WritersReplies: 6Last Post: 26th Aug 2007, 12:10 -
Error with DVD Decrypter...
By hiimbored in forum DVD RippingReplies: 29Last Post: 4th May 2007, 21:37
