  1. I was trying to make a vcd with the new type of format "mkv". Some of the mkv files were able to be taken apart and put back together. When I try to do a another series, I could not save the audio 1(as seen on the picture) because the wave is unsopported. Anyone know a way I could save audio 1 in a wave/pcm format. Is there a codec I could download to fix the problem. Any help will do. Thanks in advanced.
    demux the audio and convert the aac audio with another aac to wav converter(gooogle).
  3. Thanks for the info. I try to convert aac file with three converters, but not one of them convert the file correctly. Do you know of any good aac to wav convert? Here the converters I used dbpoweramp, Xilisoft MP3 WAV Converter, and Easy CD Ripper. I'm so close to giving up , and I really don't want too.
