I want to make one or more video DVDs out of twelve AVI files I have.
These videos are 30 mins long each.
I tried making a DVD with 3 of the AVIs using Nero 6. It just showed 50 mins of black. I tried several video convertors to make MPEGs out of them but either they either made poor quality video, or would not load the file. One suggested that I dont have the correct codec. They play OK in Windows Media player and Nero Showwtime OK. My friend has DVD architect and he had problems with the files.
By using the convertors I learned the files had resolutions of [464x352] [480x368] [448x336] [528x400] and mp3 audio that varies between 201kbs to 210kbs from file to file.
I want to burn these onto DVD(s) and preserve as much of the videos picture and sound quality as I can but I don't know how. Can anyone help me out?
Results 1 to 22 of 22
Lets just say I convert to MPG2 for example, since the resolutions differ do I have to make the output file's resolution the same as the original or will they all have to be converted to a standard resolution? If so would I round is up or down?
From the resolutions I posted previously, should I convert to PAL or NTSC (my player supports both).
Thanks -
Originally Posted by mr_tinka
The frames per second of the original avi's will determine if you should use PAL or NTSC.
From the video aspect ratios you mention, I would probably encode to half D1.
Lets just say I convert to MPG2 for exampleCheers, Jim
My DVDLab Guides -
Try VSO DivXtoDVD It is free, and the newest version allows you to put multiple files on the input field for encoding. It will also "force" your output to be DVD compliant.
Thanks Soopafresh, VSO DivXtoDVD did the trick.
There is something I want to ask about this program. Is there any way of calculating the size of the output in MB before starting the conversion? -
I have been converting DivX and Xvid files.
I haven't found any solution for the output size calculation, which doesn't bother me, because the output size has always been much lower than I would expected (for full resolution DVD). -
Don't know about this particular app, but generally, if you're trying to squeeze in 6 hrs of video on a DVD, I'd suggest 352*240/288 (NTSC/PAL) mpeg1 instead of 1/ D1, mpeg2. It's not enough bitrate room for 1/2 D1.
/Mats -
Another (not as good as encoding to the correct bitrate to start with, but obviously the only way, using some apps) way is to just encode and author, then use DVDShrink to get the output down in size.
/Mats -
Originally Posted by mats.hogberg
Speaking of VSO DivXtoDVD, I think that this application deserves attention of experts on this forum. It is very stable, fast, the output video seems to be of very good quality and in unexpectedly low output size, for full resolution PAL or NTSC DVD.
The quality of output DVD video (seems to me) comes very close to that obtained with Procoder 1.5, but in much smaller output size.
I'm an amateur who likes to play with applications, so my humble opinion is not relevant in any sense, but I really would like to see what someone with true knowledge, would have to say about this tool, regarding DivX to DVD conversions. -
I am tempted to give it a try - but if it doesn't even include a bitrate setting, I doubt I'm going to fall in love....
/Mats -
psh, 6 hrs can go on DVD @ FULL D1 (provided there isn't any audio) using KVCD templates. Just not using this app. But, even using this app then you shuold be able to fit 6 hrs Half D1 on DVD....maybe
What is 1/ D1 ? -
Originally Posted by mats.hogbergCheers, Jim
My DVDLab Guides -
Originally Posted by funkguy4
/Mats -
Seriously - thare aren't that many silent movies these days, and 1680 is still too low.
/Mats -
The most I ever got, in watchable quality, was 16 hours +- using KDVD templates, 1/2 D1, slightly customized.
Cheers, Jim
My DVDLab Guides -
Originally Posted by reboot
what customizations?? -
I encode at 1/4D1 not the 1/2D1, which happens to be the same size as my source. Why resize?
I also encode at 29.97fps, and don't use pulldown, again, because of my source, I don't want to do any changes here.
I also add noise reduction filter, to help with the output quality.
I save elementary streams, then author in DVDLab Pro.
End result is better than the "regular" KDVD settings by quite a bit.
Doing 6 hours, the OP could use my settings (or very similar) and bump the Q up to 100, and it would probably just fit nicely.Cheers, Jim
My DVDLab Guides
Avi to DVD Problems
By RBCC in forum Authoring (DVD)Replies: 6Last Post: 9th May 2011, 14:55 -
Avi to dvd Problems on a mac
By Cruz240sx in forum MacReplies: 6Last Post: 19th Apr 2009, 19:47 -
AVI to DVD Problems
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 3rd Oct 2007, 01:23 -
Two problems with avi -> DvD ffmpg
By abassili in forum ffmpegX general discussionReplies: 17Last Post: 12th Jul 2007, 19:36 -
DVD to AVI Problems
By Harvey__ in forum DVD RippingReplies: 2Last Post: 31st May 2007, 19:04
