I'm getting this error when I try and get the wave file from my movie screener Hotel Rwanda.."the requested audio compression is not compatable with the input formate. Check that the sampling rate and channel count of the input match those of the requested formate."
I've have the audio set at no comresion (PCM)
Audio stream rate 48000Hz 5 channel stereo
Video stream decompressor XviD Mpeg-4 codec
Need help on this one , I also have Tmpeg & have heard I can use it but always have used Virtual Dub so I dont know how?
Thanks all for you tips & help.![]()
Closed Thread
Well I found something that I'm no good at.
not sure you're supposed to have that/copy it BUT that's not my call (attn. mods)
i'd try loading it into VDub and loading it up into GSpot to find out the decoder required for the audio format.
Try virtualdub-mod or virtualdub-ac3.Cheers, Jim
My DVDLab Guides
Originally Posted by reboot
Its the only screener Ive had trouble with, lol
No hockey... canadian's have to stick together, thanks againWell I found something that I'm no good at.
I see that virtualdub-ac3 isn't listed in the tools section yet. Google it, and download. It'll rip the audio just like regular vdub.
Cheers, Jim
My DVDLab Guides
virtual dub não abre arquivos cokm codec xvid
By sandroguchilo in forum AudioReplies: 3Last Post: 14th Dec 2010, 16:43 -
Working with Subtitles on a 64-Bit System: XVid, SUPER, & Virtual Dub
By jdanniel in forum SubtitleReplies: 17Last Post: 22nd May 2010, 13:08 -
virtual dub xvid codec encoding w/o profile
By caner12 in forum EditingReplies: 7Last Post: 5th Jul 2009, 12:08 -
xvid encoding in Virtual Dub, stats file?
By Xavier in forum Video ConversionReplies: 4Last Post: 10th Feb 2009, 08:46 -
how to set max bitrate(xvid virtual dub)
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 16th Feb 2008, 08:54
